It is currently Thu Sep 18, 2025 7:42 pm
 Post subject: fingerboard oil
PostPosted: Sun Oct 04, 2020 11:48 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I've never oiled the fingerboards on the guitars I made. Tempted to try, some of them look 'light' and I'm hoping that a touch of oiling would bring up the grain and do something, for want of a better phrase, to bring some 'depth' to the fingerboards.
So...common suggestion is to use 'lemon oil', which is about the cheapest thing at the grocery store sold as a wood polish.
I found lurking in a closet. two bottles we bought years ago, one labeled 'teak oil', quite fluid, and another labeled 'scandinavian oil', of motor-oil consistency.
Three questions, (1) is what I mentioned typical of what oiling fingerboards is meant to accomplish and (2) are these furniture-care oils appropriate for fingerboard application and (3) what's so special about lemon oil?
Thanks, folks.
Peter Havriluk
 Post subject: Re: fingerboard oil
PostPosted: Sun Oct 04, 2020 11:51 am
I (and others too) use Howard's Feed and Wax.
PostPosted: Sun Oct 04, 2020 12:53 pm
I use paste wax. Never use oil because it will permanently soften wood.
PostPosted: Sun Oct 04, 2020 1:11 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
+1 for Howard's.
PostPosted: Sun Oct 04, 2020 1:33 pm
Last Name: Kincheloe
I oil for cosmetic reasons. Most of my fingerboards are rosewood, and oiling upfront means the whole thing is darkened, whereas leaving it bare will absorb oil from fingers while playing and develop a characteristic pattern of dark spots according to what frets are used most often. When boards get grubby, I scrub them clean using water on bits of paper towel, and then re-oil.
I used to use pure walnut oil because I had it. Then at some point bought a bottle of Music Nomad F-One oil to try, and now use it because I have it. Both are low viscosity, and produce very similar results.
PostPosted: Sun Oct 04, 2020 1:52 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Dennis, thanks. My takeaways are 2: First 'because I have it' and second, 'low viscosity'. Both components are on hand....
Peter Havriluk
PostPosted: Sun Oct 04, 2020 2:36 pm
Mineral oil is the major component of most "lemon oils" ("lemon" is the artificial scent that is added). It is also sold in small bottles as woodwind bore oil, for oiling - you guessed it - the bores of woodwinds. People use it to oil wooden salad bowls.
Somewhere around here I have a small bottle of bore oil for my oboe and cor anglais, which I occasionally use to oil fret boards. when I run out I will buy a big bottle of mineral oil and refill it.
I also had a beeswax and lemon oil mix that I've used on fretboards (who knows where these things get off to!). In moderation it worked o.k..
Most things marketed as "teak oil" and "Danish oil" (Scandinavian oil?) are intended to be finishes rather than cleaners. They usually rely on boiled linseed oil or some other drying oil as a major constituent, and will build up on a fretboard with repeated application.
Mineral oil, lemon scented or not, seems to clean and darken fretboards as well as most things and is reasonably cheap. Used in moderation it shouldn't hurt the wood (It will "kill" the strings if you oil them)
PostPosted: Sun Oct 04, 2020 3:01 pm
Not really true. Certainly depends on what oil is used. Motor oil? Yes.... Had a client bring a Tele back in the early 80's who used motor oil frequently, and the wood became so soft I could pull the frets out with my fingers. Also - a little goes a long way. I used lemon oil for decades with no problems, but recently switched to Howard Feed'n'wax.
PostPosted: Sun Oct 04, 2020 3:29 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
thanks, everybody. Wonderful symposium!
Peter Havriluk
PostPosted: Sun Oct 04, 2020 6:03 pm
https://findanyanswer.com/open-detail/502634A7
An article I meant to post with my reply (short term memory fail).
These users thanked the author Clay S. for the post: Pmaj7 (Mon Oct 05, 2020 4:45 am)
PostPosted: Mon Oct 05, 2020 7:16 am
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
I use lemon oil or thinned linseed oil, HD an buff with renaissance wax from amazon
PostPosted: Mon Oct 05, 2020 5:00 pm
At 15 bucks for 16 oz in Walmart , which will do hundreds of FBs, Howards Feed-n-Wax is a steal.
I bought 2 oz in UK and have done at least 30-40 with it, still got half (wasted a lot!)
And doesn't really have any cons, as far as I have found or heard.
PostPosted: Mon Oct 05, 2020 6:07 pm
I learned about Howards on this forum and it's great stuff for sure. It's what I use now.
PostPosted: Mon Oct 05, 2020 6:45 pm
I use Howard's products on antique furniture (restor-a-finish, feed n' wax), but still prefer mineral oil for fingerboards.
PostPosted: Mon Oct 05, 2020 7:32 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I've been using run of the mill mineral oil for a long time. The kind you can get at the drug store.
PostPosted: Mon Oct 05, 2020 9:33 pm
I bought a bottle of “fingerboard oil” from StewMac years ago. Just ran out recently. Have no idea what was in it but it seemed OK.
Thanks for the tip on Howard’s.
PostPosted: Tue Oct 06, 2020 9:24 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
I think there are a number of products that do an adequate job of sealing and protecting fingerboards, but mineral oil is NOT on my list. Mineral oil does not polymerise or “dry”, so after application it continues to react with and draw skin oils and dirt into the wood. In my opinion, a fingerboard oil/wax should dry quickly and be non reactive with skin oils.
I tend to use Howard’s Feed n wax on ebonies, and artist-grade linseed oil on rosewood. Both are vigorously removed within 10 minutes of application. Conditioning once per year is plenty.
My 2cents to the continuing debate.
PostPosted: Tue Oct 06, 2020 8:57 pm
I like the fact that mineral oil doesn't dry or polymerise. I think the the mineral oil cleans and removes finger grunge and dirt from the fingerboard and adds a little oil to the wood. I agree, cleaning once or twice a year is plenty.
PostPosted: Tue Oct 06, 2020 10:06 pm
First name: Jay
City: Bothell
State: Washington
That hasn't been my experience, for whatever it's worth.
